Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Maxwell Error in plotting the B Field vs position › Reply To: Maxwell Error in plotting the B Field vs position
Navya Chode
Hi Vinay_G,
You need to mark the circle you have drawn as a non-model in its properties. did you do that?
Also, I did not understand what do you mean by "select the geometry circle in the "create a field report" dialogue box vs the position"
Navya
