Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with Contact Simulation in Mechanical APDL Reply To: Problem with Contact Simulation in Mechanical APDL
Franzanstein
Hi Peter!
Thanks a lot for the fast reply! I was wondering if there is a different way to achieve the updating of nodal positions or if NLGEOM is the best way to handle the simulation? (Also do you maybe know where I can find detailed documentation of the NLGEOM setting? I couldnt find much in the contact guide except for some information on how NLGEOM influences the pinball region).
I have tried updating the stiffness at each iteration (Keyoption 10=2) but again the simulation and this setting only work when NLGEOM is activated.
