Ansys Learning Forum Forums Discuss Simulation General Mechanical LS-OPT having same results in different points Reply To: LS-OPT having same results in different points
cct
We set the directory of the LS-Prepost exe for the command in LSPP stage.
In the cfile, we define two parameters in the way as following figure:
In LsPrepostOpt.inp of 1.1 and 1.2, the values of parameters (the lighting parts) are different.
