Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › LS-OPT having same results in different points › Reply To: LS-OPT having same results in different points
igandiko
What command did you define in LSPP stage? Post a snapshot of LSPP stage and also show how you defined parameters in the cfile.
Is there any difference in LsPrepostOpt.inp file in 1.1 and 1.2? This is the file LSPP runs to create new geometry. The input file defined in the stage is copied as LsPrepostOpt.inp to 1.1, 1.2, etc with parameter values replaced by ls-opt.
You can also refer this example https://www.lsoptsupport.com/howtos/integrating-pre-processor/ls-prepost
