Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › LS-OPT having same results in different points › Reply To: LS-OPT having same results in different points
cct
We used to check the input file created in stage/1.1, 1.2, and 1.3 using LSPP and found there is no any change. Yet in the lsopt_run_db.lsox, it shows the different parameter values (as following figure). Thus, we are confused whether the parameters apllied into LS-OPT well.
