Ansys Learning Forum Forums Discuss Simulation Electronics How Can I import a Spice model in a Q3D circuit? Reply To: How Can I import a Spice model in a Q3D circuit?
Dan Dv
If you really want to see the internal structure of a SPICE file, pretty much the only way to do that is to look at the file in a text editor. If you are importing it into AEDT Circuit, you will only be able to see the external nodes in the schematic symbol, and any parameters as you are showing.
