Ansys Learning Forum Forums Discuss Simulation Photonics Saving delta of two field profile monitors Reply To: Saving delta of two field profile monitors
Guilin Sun
I did not find anything wrong in your script. You may try to create a matrix dataset, similar to vector dataset, and see if they are the same. You may need to clear the data again.  If there is no other script in between, there is no reason the data shows differently.
