Ansys Learning Forum Forums Discuss Simulation Fluids DPM model VS DDPM model Reply To: DPM model VS DDPM model
1) Open the wall panel up. Check it's set as reflect in the DPM tab.
2) Read the definitions in https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/flu_ug/flu_ug_fvdefs.html
3) Can you plot the flow velocity in that region? Depending on how the flow is behaving near the wall(?) you may have a problem with the flow.
