Ansys Learning Forum Forums Discuss Simulation Fluids Oilflow pathlines get aborted Reply To: Oilflow pathlines get aborted
davide.salvatore
Thank you for the hint. I have searched the .cas.h5 file and two lines result. Pointing in the 2021R2 direction:
(parallel/function "fluent 3ddp -r21.2.0   -ic=default -node -t12")
ANSYS_FLUENT 21.2 Build 10201
Though this file was opened with the 2021R2 version and overwrited from there, so probably this doesn't help that much.
I have tried with particle tracking and it works (as well as the Pathlines plot works if I dont use the oilflow option). Just to be sure that I performed the test you had in mind: I created an injection as a surface, selecting the body surface as source; the particle type I selected was Massless and I left the DPM off.
