Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Verification of repeated eigenfrequencies › Reply To: Verification of repeated eigenfrequencies
If the structure has two planes of symmetry (both geometric and boundary conditions), then you expect repeated eigenfrequencies because the structure will move in the XY plane for one and move in the YZ plane for the repeated frequency due to those being the planes of symmetry. If the structure, including the mesh, is not perfectly symmetric, then a small difference can be introduced between the two planes, but I would still call that a repeated eigenfrequency.
It’s possible to have two very close frequencies that have totally different mode shapes. You can see that when you animate the two modes. You can’t tell from the values alone, you need to look at the mode shape.
