Ansys Learning Forum Forums Discuss Simulation General Mechanical ANSYS AQWA – White Noise input Reply To: ANSYS AQWA – White Noise input
javier.medina.galera
When I try to import a *.wht file from a wave generated in matlab and run the analysis, the duration is automatically extended to 7200s despite the duration indicated in the analysis settings, is there any way to change that??
Thank you very much!
