Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DPM model VS DDPM model › Reply To: DPM model VS DDPM model
Two way coupling means the particle momentum/temperature is seen by the flow field. Otherwise the trajectories are governed by the flow but the flow isn't affected by the particles. Particle-particle is four way coupling.
Wall rebound tends to be set in the wall boundary condition, under DPM.
