Ansys Learning Forum Forums Discuss Simulation General Mechanical ‘Large deflection on’ non-linearity VS ‘frictional/frictionless support or contact’ non-linearity. Reply To: ‘Large deflection on’ non-linearity VS ‘frictional/frictionless support or contact’ non-linearity.
peteroznewman
Array Frictionless support is a linear boundary condition. It works in linear analyses like modal and harmonic response. Nodes on the surface cannot separate in any analysis.
Frictionless contact is a nonlinear contact. Nodes on the surface can separate. ANSYS Mechanical will automatically convert a closed frictionless contact into a frictionless support in a modal analysis, but will ignore an open frictionless contact in a modal analysis. In a Static Structural or Full Transient Structural (not MSUP) the nodes in the contact can open and close as needed during the solution.
