david.ryvol
Hi, I have the same problem... package is ANSYSACADEMICSTUDENT_192_WINX64
I tried everything: reinstall, redownload, your solution, nothing helps
Could you share with me where exactely did you install the software? Was it directly into your folder like C:unzipped folder or
C:unzipped folderANSYS IncANSYS Student ?
Thanks, David
Hi Win,
Okay I have solved the problem.
The required files were on the computer but ANSYS workbench couldn't find the path to the Addins, hence my problem.
I tried manually but that didn't work either, so, after uninstalling all of the components  :
1) I unzipped the downloaded file gain
2) Loaded the complete unzipped file folder intro a directory that I created
3) When the installation prompted the directory, I changed the path to the chosen directory
In hindsight it seems obvious as most installation problems are.
I am now looking forward to using the ANSYS software !
Thanks for offering a student version of your software.
Erik
P.S. : For those interested I am using a 5 year old Windows7 based workstation (i7-2920XM, 16 GB, NVIDIA Quadro 2000M) which is more than adequate for the student version.
