Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Sinusoidal value for current density (electric potential value in MHD) › Reply To: Sinusoidal value for current density (electric potential value in MHD)
Rahul
Unload the previously loaded UDF and then use expression. Better if you use latest version.
And go through the entire Fluent setup visiting each panel and make sure that the values are entered
correct format.
Rahul
