Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Appropriate way to assign excitation to a Log-Periodic-Dipole (Wire)-antenna. › Reply To: Appropriate way to assign excitation to a Log-Periodic-Dipole (Wire)-antenna.
AncS
Hello Sahas,
Can you please check if an open boundary condition or any equivalent boundary to absorb the fields radiated from the antenna is defined in your model?
You can try simulating 'Log Periodic Dipole Array (LPDA)' from the Antenna Toolkit ACT extension which is easier to use, for your reference.
Hope this may help.
Regards
Anchal
