Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error in mechanical (fillet)- Unable to write APDL input file › Reply To: Error in mechanical (fillet)- Unable to write APDL input file
Hello. The .mechdb or .rst files are not being generated. I retained a failed design point (dp2) which displayed the same error- Unable to update setup. Unable to write APDL input file.
In the results I can see that I have a folder for design point 2 and inside I have the following subfolders:
The DM folder is empty. Inside the MECH folder I can see the Maxwell solution folder and the following files without any .mechdb file:
While running the simulation, first the Maxwell solution gets updated, then the structural analysis update starts, but as soon is starts it throws the error message and moves to the next design point.
Also, for the first initial design point the analysis was successful as I am able to run any valid parameter variation manually in mechanical and the following files were available from it for the design point 0:
