Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Calculating the phase in FDTD › Reply To: Calculating the phase in FDTD
Guilin Sun
There are 2 steps using script to get the phase:
1: get the field components. As you know, the phase is associated with Ex,Ey, Ez (or H components). So you can use
E=getresult("monitor","E");
Ex=E.Ex;
Ey=E.Ey;
Ez=E.Ez;
similarly you can get x,y,z and f.
2: get the phase. for example for Ex, you can write
xphase=angle(Ex);
which will be a function of xyz and f.
In addition:
1: you can use Ex=getdata("monitor","EX") if you know you want Ex
2: you can use pinch to remove singular dimension: https://optics.ansys.com/hc/en-us/articles/360034405674-pinch-Script-command
Please note that, a plannar frequency-domain monitor gives E/H/P as a function of x,y,z and wavelength/frequency. So in general the phase extracted from a monitor will have 4 dimensions, although one of the xyz will be singleton.
You can specify a particular dimension. Say you have a xy plane monitor. The phase will be
Phase(1:nx,1:ny,1,1:nf)
Using pinch to remove z singleton; phase=pinch(phase).
If you want to image phase or a specific wavelength, you can specify the frequency point, say fn (1<=fn<=nf), then
Image(x,y, pinch(phase(:,:fn)), “x”,”y”,”phase”);
