Ansys Learning Forum Forums Discuss Simulation General Mechanical Highly Imbalanced Work Load Reply To: Highly Imbalanced Work Load
peteroznewman
It's a warning, not an error, so you don't need to fix this problem, but if you do fix it, the solution time might go down by a few seconds.
Open the geometry in SpaceClaim. On the Workbench tab, click the Share button. You might need to extend some edges to get the edges to imprint onto the adjacent face.
In Mechanical, delete the contact B1-1. Shared Topology was created in SpaceClaim and the mesh is now connected by sharing common nodes at the imprinted edges.
