Ansys Learning Forum Forums Discuss Simulation Fluids Is it possible to extract data from .dat or .out files with python into a csv file? Reply To: Is it possible to extract data from .dat or .out files with python into a csv file?
I don't think so, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_chp_files.html may be of some help. Not helped that some of the file is in binary. There's a TUI option under /file to set the format of .dat (not .dat.h5) to write in non-binary. How readable that is will depend on the size of the model: try it with something small.
However, for the above you may find it's quicker to open case & data and export an ASCII format file of just position, velocity components and pressure. Far less data to try and figure out!
File-Export-Solution Data
