Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › why contour is not plotted by ansys even showing proper stress pattern? › Reply To: why contour is not plotted by ansys even showing proper stress pattern?
peteroznewman
55 mm of deformation at the top of the femur is a sign that there is a mistake in the model.
The Young's modulus for the top half may be off by an order of magnitude. Check values and the units that were used.
