Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How does Outlet Pressure changes effect the flow regime in a supersonic Flow? › Reply To: How does Outlet Pressure changes effect the flow regime in a supersonic Flow?
March 4, 2022 at 6:26 pm
Dear Karthik
Thanks for the reply. I know everything about the CD nozzle theory. What I was wondering about is related to ANSYS Fluent.
On this website: https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node244.htm
Under the Defining Static Pressure section it says : "To set the static pressure at the pressure outlet boundary, enter the appropriate value forGauge Pressurein thePressure Outletdialog box. This value will be used for subsonic flow only."
This manual basically says any value for pressure outlet will not be used if the flow is supersonic. How can this be? How does Fluent calculate the exit pressure in this case? Every time I change the value of gauge pressure at the outlet I get a different result. Shouldn't I get the same result even if I change the outlet pressure? Are manuals wrong in this case?
