Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Static Structural Analysis – Changing pressure value doesn’t change node location › Reply To: Static Structural Analysis – Changing pressure value doesn’t change node location
qvly
Hello Peter
Thank you so much for your help. The displacement scale factor was the reason why my node location was off. I have been stuck on this problem for so long and I finally fixed it. I really appreciate your help.
