Ansys Learning Forum Forums Discuss Simulation Fluids Overlapping contact regions Reply To: Overlapping contact regions
canderous
Thanks for responding.
The fluid domain is inside the wavy tube in between the cells. I've tried fiddling with the tolerances in the contacts menu to no avail. I've thought about just deleting all the contact regions but would this still make the simulation run properly? Is there anything I have to do to compensate for these missing contact regions? Also sorry but which surfaces/volumes are you actually referring to and how do I know these are correct?
