Ansys Learning Forum Forums Discuss Simulation Fluids Mean age of air (MAA) with 2 inlets Reply To: Mean age of air (MAA) with 2 inlets
You'd typically run the MAA UDF on a frozen flow field after running the model. So in that case change the mouth to a wall and then run MAA. The flow field is unchanged but the scalar won't see the second inlet.
