Ansys Learning Forum Forums Discuss Simulation Fluids X-momentum source using Fluent UDFs Reply To: X-momentum source using Fluent UDFs
If you plot the scalar what do you see? Remember the source you're adding is N/m3 so make sure the scalar value is big enough to be seen by the flow.
