Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with Open Channel Wave BC › Reply To: Problem with Open Channel Wave BC
Keyur Kanade
Assuming your mesh is of good quality, please make sure first you have defined materials correctly. Then check if you are able to run without wave bc. Run only vof and make sure it runs correctly. Then use wave bc.
Please go through help manual for more details 47.4.1. Multiphase Model Dialog Box (ansys.com)
You can also find some videos of vof online.
Regards Keyur
