Ansys Learning Forum Forums Discuss Simulation General Mechanical 2D Geometry in SpaceClaim to Static Structural Model Reply To: 2D Geometry in SpaceClaim to Static Structural Model
peteroznewman
Go back to Spaceclaim. You have one surface with six faces. You need six surfaces.
The simple way to get six surfaces is to pick one face, type Ctrl-C then Ctrl-V. That will copy the face and paste it in as a surface. Do that five more times and then delete the surface with six faces.
On the Workbench tab, click the Share button. Now the mesher will mesh all six surfaces with a connected mesh, but you will be able to assign a different material to each surface.
