Ansys Learning Forum Forums Discuss Simulation General Mechanical 2D Geometry in SpaceClaim to Static Structural Model Reply To: 2D Geometry in SpaceClaim to Static Structural Model
Naresh Patre
Is this a display issue or import issue? Can you select the face selection filter and then try to select all faces in the graphics window and see how many faces get selected. If you are seeing more than 1 face, then please check what Display options have you selected. The Shaded Exterior Option will not show up the edges. Try switching to other Display options from the list to display the edges.
