Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How can I mesh/couple edge of a shell element to a beam element surface? › Reply To: How can I mesh/couple edge of a shell element to a beam element surface?
February 17, 2022 at 5:27 pm
What is the diameter of the beam and the thickness of the shell. If they are the same material and the dimensions are not so different, do you even need to model the beam?
