Ansys Learning Forum Forums Discuss Simulation General Mechanical Getting type string data from Mechanical script to APDL Command Snippets (via ARGs or otherwise) Reply To: Getting type string data from Mechanical script to APDL Command Snippets (via ARGs or otherwise)
Erik Kostson
Yes it is quite OK I think - I tried it on my end and it generated all the files based on the number of named selections and their names, so seems to be working (in the solve.out it will not write out all the iterations in the loop).
All the best
Erik
