Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Getting type string data from Mechanical script to APDL Command Snippets (via ARGs or otherwise) › Reply To: Getting type string data from Mechanical script to APDL Command Snippets (via ARGs or otherwise)
fruswrit
Hi Thank you. I was trying to avoid it as it is kind of a pain, but it may be the only way.
Cheers
