Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Re: Surface temperature › Reply To: Re: Surface temperature
February 17, 2022 at 2:13 pm
With node values on:
With node values off:
with node values off:
Although I have to say - there are a few cooling pipes (cool water flowing inside) embedded in the solid a small distance beneath the top surface. Do you think they are the culprit?
But then, the bottom surface of the solid block also has a fixed temperature of 31C, and while it is located a long distance from the cooling pipes, it also exhibits a similar pattern to the top surface (temperature differs near side walls). So maybe it is not the cooling pipe effect. Anyhow, if the temperature is fixed, it should be fixed throughout the surface don't you think (regardless of the presence of cooling pipes or not)?
