Ansys Learning Forum Forums Discuss Simulation Fluids Divergence problem of the spray simulation with Eulerian wall film Reply To: Divergence problem of the spray simulation with Eulerian wall film
Given the number of incomplete particles drop the particle time step by an order of magnitude. Also turn off splashing. See how that goes. Basically, to diagnose problems we turn stuff off until it works and then slowly turn things back on until they don't. From there it's usually fairly easy to work out what the root cause of the problem is.
