Ansys Learning Forum Forums Discuss Simulation LS Dyna how to extract tress results to text or excel from workbench solution? Reply To: how to extract tress results to text or excel from workbench solution?
srira
Thanks for that post, I already explored the chart option, but it displays only maximum and minimum values. But, I have selected ten nodes and obtained the results for that in each case. (stress_1 denotes ten nodes at some location; output stress_2 means ten nodes at some other location...), If I right-click on a particular output solution, I can export or view the results at each node saved in a particular name. So, the chart option not helping. kindly refer to the attached image.
