Ansys Learning Forum Forums Discuss Simulation Electronics How to determine the depth of a 2D model Reply To: How to determine the depth of a 2D model
Amir_agha
Hi @nchode Thank you for your response.
My 3D model is a symmetric one.
I just realized that I must use 2*830mm (1660 mm) if I want to have the same result for both 2D and 3D simulations.
It makes me confused since based on the same volume of the core (I mean if I want to determine the depth of the 2D model to have the same volume as the 3D model), the depth must be 623mm. However, 623 mm does not give me the correct result.
At this time, I am not sure which one must be selected.
