Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Multi Layer Cylinder Shell › Reply To: Multi Layer Cylinder Shell
francescocurzio
thank you so much, i resolved the problem using the same number of elements in the circumfernetial direction for each components. Probably this will lead me to have a coarse mesh in the outer layers, but i cant use an extremely fine mesh in the inner layers due the elevated number of elements in the model.
