Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Scheme file causing fluent crash on cluster › Reply To: Scheme file causing fluent crash on cluster
February 18, 2022 at 4:41 pm
It's not the only line in the file. I have lines before and quite a few after. This is just the line that's causing the error. I've said earlier, it works on my local PC but it fails on the cluster. But when I interactively type these commands on the cluster, it works. Is there a separate way to invoke the scheme file without having to run interactively? Is -i the only way to call the scheme file?
