Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Scheme file causing fluent crash on cluster › Reply To: Scheme file causing fluent crash on cluster
February 17, 2022 at 10:14 pm
vedama
The Scheme commands work when I type them out interactively on the cluster but it produces the error when I run it as a journal script from the bash line using -i
Is there another way to call the Scheme (.scm) script? Is it different from -i which is used for journal files?
