Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Contact Loss Using HPC › Reply To: Contact Loss Using HPC
February 16, 2022 at 10:39 pm
Thanks for your suggestions. I changed Eroding_Surface_to_Surface contact to Eroding_Node_to_Surface contact and it worked. Now Rigid finite elements (impactor) hitting target finite elements (composite) can recognize each other successfully. But there is one more issue here. My target is composed of two parts: finite elements and SPH nodes. I use Tied_Node_to_Surface_offset to tie these two materials together but I get this error:
Please let me know if you have any idea. Thanks.
