Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Contact Loss Using HPC › Reply To: Contact Loss Using HPC
Reno Genest
Hello @MohammadMahdi
The node is not tied. Try setting SST=-1 and MST=-1. You need to set SST and MST to a negative value larger than the gap between the node and the segment and it should get tied. The value of -1 may be a bit too large, but it should work.
Let me know how it goes.
Reno.
