Ansys Learning Forum Forums Discuss Simulation General Mechanical Power line cable behavior simulation Reply To: Power line cable behavior simulation
OROI
Here is error log:
*** WARNING ***CP =0.967TIME= 00:17:50
Element shape checking is currently inactive.Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
Material number 28 (used by element 802) should normally have at least
one MP or one TB type command associated with it.Output of energy by
material may not be available.
No constraints have been defined using the D command.
*** WARNING ***CP =1.482TIME= 00:17:50
Pivoting has been activated for the Distributed Sparse Matrix Solver .
The memory required may greatly exceed the predicted amount.In that
event, use the DSPOPTION command to change the memory mode and/or
memory size used by the Distributed Sparse Matrix Solver.
*** WARNING ***CP =15.959TIME= 00:18:05
*** WARNING ***CP =70.793TIME= 00:19:00
*** WARNING ***CP =667.793TIME= 00:29:20
*** ERROR ***CP =828.303TIME= 00:32:06
Solution not converged at time 6.20348279 (load step 4 substep 49).
Run terminated.
*** WARNING ***CP =828.303TIME= 00:32:06
The unconverged solution (identified as time 8.5 substep 999999) is
output for analysis debug purposes.Results should not be used for
any other purpose.
