Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Power line cable behavior simulation › Reply To: Power line cable behavior simulation
OROI
I tried use 1/4 force and then it solves, but if force is higher then i get error. I made horizontal cables little bit shorter and also stiffened steel supports. After those changes it solves with full force. Do you have some ideas why it can't solve if the model is more flexible. The point when error happens is about when the cable drop force is high at first time and this is after when load force is no more active.
