Ansys Learning Forum Forums Discuss Simulation General Mechanical Temperature dependent heat generation (APDL Commands) Reply To: Temperature dependent heat generation (APDL Commands)
rbaheti
So I figured out where I was doing wrong and rectified it (I think...)
The sim now works. Is there a way terminate the heat generation once the temperature of the entire body (i.e. the last node in the volume) crosses a temperature threshold?
