Ansys Learning Forum Forums Discuss Simulation Photonics nesting or dependent structure groups Reply To: nesting or dependent structure groups
Guilin Sun
Structure group cannot access other objects outside its scope.
To do so, you have two options:
1: use analysis group. it can access its member structure group, source and monitors. Please refer this example:
Metamaterial parameter extraction - Smith
2: through "model" to access. Please refer band structure examples: Bandstructure of planar photonic crystal with a square lattice
Please read the example instructions, open the files and check related objects and scripts to see how the parameters are assigned and passed.
