Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Why does my Froude Krylov graph shows a straight line, but my hydrostatic result indicated otherwise › Reply To: Why does my Froude Krylov graph shows a straight line, but my hydrostatic result indicated otherwise
haruroslan
Sorry, I am currently using a student account and won't be able to access those links, as I assume those are under ANSYS Customer Portal Hope there's another way to see it. (Edit: I have solved a way to manually plot it using the data from AqwaGS. Thanks for the tip Mike!)
And yes I have used this software with a similar setting for two separate designs, this error only came up here.
