Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to plot field overlay of X component of Mag_B? › Reply To: How to plot field overlay of X component of Mag_B?
Navya Chode
you can create a polyline as the circular path (OR any path you want) first -> use field calculator to create named expression Bx
In field calculator, Input: Quantity->B
Vector: Scalar?->ScalarX
Add..->Type the name as "Bx"
Create a field report-> select the circle(or the path you crated) in geometry ->add Bx from Calculator Expressions->New report
Regards Navya
