Ansys Learning Forum › Forums › Discuss Simulation › Fluids › About setting the number of cores (threads) in chemkin › Reply To: About setting the number of cores (threads) in chemkin
judy.cooper
There is no need to make any adjustments. For 2021 R2, this setting was removed. Chemkin is not parallel like CFD, and it was found that setting the threads >1 resulted in little speedup.
The main speedup advantage Chemkin has is for parametric runs, where Chemkin can perform the calculations for all parameter combinations simultaneously.
