Ansys Learning Forum › Forums › Discuss Simulation › Fluids › regarding soil modeling and conjugate heat transfer between air and soil › Reply To: regarding soil modeling and conjugate heat transfer between air and soil
If you do a share topology step in SpaceClaim it should remove the nonconformal bits and make meshing easier. You then need to make sure you resolve the fluid bit enough to get the flow right.
I'll look again in the morning as the images aren't showing up for me (yet).
