Ansys Learning Forum Forums Discuss Simulation General Mechanical Consider ambient pressure into structure analysis Reply To: Consider ambient pressure into structure analysis
Rameez_ul_Haq
Edit more tidying at author's request.
The pressure is constant so if you increase the area, the force increases by the same proportion. Nevertheless, the force will exist, signifying that displacements must exist.
